1 - 16 of 16 Posts
I am working on my 520 liter, 26" 13 hz tube for a UXL 18 (driver is still a couple weeks out). I got lucky and found a 26" tube sitting in a local warehouse, which is usually a special order item. What I didn't realize until I bought it is that it is the "Finish Free" style-- with their "Duraglas" coating on the inside, which chips off like 3/64" thick chunks of plastic--with some of the cardboard backing. I have read about people peeling off the film coating from the inside of their tubes, but this seems to be something different.
I would like to leave it in place, if possible, because it is so thick and doesn't come off well. I can just cut the endcaps to account for the lining; I am wary of gluing them on, and was planning on bolting them onto the sonotube through a thin strip wrapped around the outside. (Unless the press-fit just comes out really, really secure.)
The 2nd issue with the lining is attaching egg-crate foam to the inside, which I understand to be a good idea. Obviously, the lining is made for things not to stick to it... maybe if I rough it up with a rasp or coarse sandpaper, I could get the foam to stick with spray-on glue? Anybody have advice or experience with this lining?
Thanks!
Haven't bought the foam yet; I was thinking 1.5" or 2. So basically a foam tube of this thickness has enough rigidity to hold its own form... sounds good, then I will proceed with the lining.
I am also planning on a ring to brace the end of the port, although I don't think I see most people doing this. Not necessary? Seems useful though, as it will alsobe the flare, hold the polyfill in place up away from the driver, and provide some mid-tube resistance to crushing in case of accidents.
The foam will hold itself in with a little tension. Trying to spray glue it would be a real pain because it sticks on contact. You can't slide it in.
If you do end up wanting to glue the foam in I would try a couple spot tests with and without surface prep to see what you're dealing with. I think sanding or rasping would get you the surface you'd need.
I think the support brace is a great idea for the reasons you came up with. Look forward to seeing your build! :T
However you mount the end caps they need to be completely air tight. Press-fit won't be enough, the caps need to be totally sealed.
Discussion Starter #7
ok... what I'm thinking of is a flexible but fairly solid strip which would wrap completely around the tube and screw through the tube into the endcaps, sandwiching the cardboard... kind of like a beadlock. I haven't thought of the perfect material yet though; I think metal might resonate. Maybe nylon, but I don't know where to find that.
Gluing would be easier, but I'm concerned about needing to get into the tube again to adjust the port, stuffing, etc.
A metal strip bolted to the end cap will not resonate. It will be constrained in all degrees of freedom. That would definitely be recommended over a nylon strip.
However, finding a strip thick enough to give you sufficient transfer of loads and still be pliable enough to bend may be a little difficult. I would recommend aluminum bar stock somewhere in the 1/8 to 1/4 inch thickness range, which you should be able to bend easily.
Thanks!
djbachelor,
Interesting project! Do you have a build thread - would love to follow along and see some photos :)
Discussion Starter #13
Thanks for the tip on aluminum bar; I might be able to come up with something like that.
What do you guys think of egg crate Memory Foam for lining the inside? I can find a 2" california king mattress topper for about $40, which is a pretty cheap price and the only thing big enough to wrap all the way around the inside (84" circumference). I don't know if it's closed or open cell though, or what the acoustic properties are. 2" foam is not really going to be blocking any low frequency waves anyway, is it?
Discussion Starter #15
Ok I found relatively cheap acoustic foam... is 2 1/2" too thick? I wanted to go with thicker because it is 80 inches wide and the inner circumference is about 82"; I figure the extra thickness will take up the slack when it's compressed into a circle and be enough to hold it against the side.
1 - 16 of 16 Posts
