1 - 5 of 5 Posts
Hi everyone,
I acquired an old pair of B&W DM-600 bookshelf speakers (made in the mid 90's) and this is the first time I've encountered a pair of HF / LF connections (I am no audiophile). After a little researching I found out that most of the time these connections are jumpered with metal plates. My speakers are not jumpered, so I was wondering if should create a jumper myself? Would I be able to purchase plates that would fit (assuming the connections are of a standard orientation), or should i wire the jumpers myself and then use a banana plug on the end?
Just thought I would check on this!
Yes. you can jumper them with some speaker wire, then use banana plugs to connect them to your amp. Welcome. Have fun. Dennis
Plain ole user
You can likely still get them from B&W, but I would just use some heavy gauge copper wire, like some 12awg electrical wire, cut and bend to fit.
1 - 5 of 5 Posts
