do you have one already, or are you just considering it for a design?
If you have it, I recommend tooling up to measure the impedance yourself. There can be quite a bit of variance among the same driver, so the one Zaph tested might be different than the one you get. Normally they are close, but it's always better to measure the one you have.
If you're just looking to virtually prototype a design then other people's measurements are the way to go. If Zaph is only off of the manuf. by 1 Ohm across the board, you can probably go with his and still design the crossover fine. Worst case, you will have to pad the tweeter slightly to compensate for the difference in efficiency. The shape of the impedance curve is what's most important (where it peaks and how it rises after the peak).
I hope this helps some.
