1 - 4 of 4 Posts
I am trying to take some measurements of the maximum SPL output of my subwoofer. Problem is REW always shows clipping when setting amp gain anywhere near high power. Is there a method that will allow REW to tell me the max SPL output somewhat accurately?
Well did you configure the Mic according to the Guide for what Windows you are running.. I would try turning down the gain of the Mic in Windows..
Check pages 24-25 of the REW Manual..
Thank you. I may have missed that portion of the manual.
1 - 4 of 4 Posts
