Hitachi 51S500
2071 Views 3 Replies 2 Participants Last post by  DonC23
Hi, noob here
I have a Hitachi 51S500 that has been working great since I have owned it. My only current issue is that a spider has set up shop in the cabinet and is driving me crazy with some cobwebs.
I think I can figure out how to open up the unit, but, I was wondering if anyone had any specific information I should consider before doing that. I am planning to do a bit of cleaning (compressed air ). I looked around for service manuals etc and other information on the web but haven't found much.
Any pointers/information sites I should check?
Thank you in advance
1 - 4 of 4 Posts
Your post has been moved to a more appropriate location to make information easier to find and to make it more likely that others who are interested will find your post.
If I recall correctly, there are screws across the bottom of the screen frame behind the grille, then the screen and frame come off with a sideways slide and tilt.
Thank you for the tip on screw location. Sorry to have posted in wrong section:doh: Thanks for moving to a more proper forum.
Is there any advice on any specific things to check while I clean the cabinet out?
Thanks
1 - 4 of 4 Posts
