hitachi 51uwx20b
4290 Views 9 Replies 9 Participants Last post by  ALMFamily
Iown a hitachi 51uwx20b tv it has a double picture. The upper left and lower right of tv screen ar more red and the picture is bent. Ican go to manual convergence and it shows the colors off of the lines in those corners.Magic focus does not work,it stops in the middle and the number 5 appears in green at the lower right corner. WHATS WRONG Thanks for the help
1 - 10 of 10 Posts
Welcome Ron. It sounds like your convergence ic (board) has gone bad. Usually not a diy project unless you are used to that sort of thing. Have fun. Dennis
Hello,
Welcome Ron. Sorry your Display is giving you trouble.
Cheers,
JJ
Hello Ron and Welcome to the Shack.
Welcome, Ron. Look to the DIY Repair forum and find the Convergence Repair sticky. Read the first ten posts very carefully. Then post a new thread for your problem in the Hitachi forum.
Dennis, we have dozens, probably hundreds, of folks who have repeired their own sets with this very common problem. If it is the common STK outputs and resistors, a person with a little soldering ability adn a manual for doing the convergence alignment can easily DIY these. Other problems that involve more troubleshooting and equipment are not good DIY projects, but these are usuall symptom-repair fixes that many can do.
Thanks
I replaced convergance chip.
1 - 10 of 10 Posts
