1 - 4 of 4 Posts
My set will turn on and sometime it will work fine for about 30 seconds the I get jumping lines and the picture and sound go out and other times I have no picture and sound right after I turn it on what could be causing this and how would I go about fixing it
Thanks Brad
Plain ole user
What kind of jumping lines? What does the image look like when it comes up?
White and black lines all the way across the screen that make the picture jump up and down. I'll try to take a picture of it if my phone will work fast enough.
Discussion Starter #4
I just tried it again to try to get a picture. This time the picture started out fine for about 10 seconds then I heard a noise like the tv was shutting off and the screen went black and the sound went with it but the tv was still on
1 - 4 of 4 Posts
