1 - 7 of 7 Posts
I'm using a 50 ft. (supposedly high-quality) video cable so I can watch tv and movies on my projector, but the quality is pretty bad. This is a high-buck projector that can run 720p and I think 1080p video, so I'm just wondering why it's such bad quality. Thanks.
Sorry, I'm not the best with projectors/video. The cable is an RCA Male / RCA Male, High Quality, Composite Video Cable, 50 ft.
It's set-up in our family room and we'll be mounting it to the ceiling for a home theater. It's about 20 feet away from the screen. Bad quality, as in pixelated kinda' like a youtube video. Definitely not HD.
Plain ole user
Composite video is not HD, just NTSC and will look pretty bad. You need to connect with component or HDMI.
It doesn't matter how 'high quality' a composite cable is, it's one of the worst. I agree with Icaillo and would bet your composite video cable is causing the pixalation.
I just checked the specs and your projector doesn't have HDMI but has others that would do much better.
The next step up from composite would be the s-video, and better than s-video would be anything else...component, VGA, RGB....
Tell us what output connections you have on your devices and someone might be able to tell you which is best.
Here is a list of the CP-X1250's inputs/outputs:
1 x VGA input - 15 pin D-Sub (DB-15),
1 x VGA output - 15 pin D-Sub (DB-15),
1 x Component video input - BNC X 5,
1 x VGA input - M1-D,
1 x S-video input - 4 pin mini-DIN,
1 x Composite video input - RCA,
1 x Component video input - RCA X 3,
1 x RGB - BNC X 3,
2 x Audio line-in - Mini-phone stereo 3.5 mm,
1 x Audio line-out - Mini-phone stereo 3.5 mm,
1 x Serial RS-232 - 9 pin D-Sub (DB-9),
1 x Network - RJ-45
Your projector does 720p/1080i, not 1080p. But 1080i is good enough and wouldn't cause pixelation.
Discussion Starter #6
Ok, that's what I figured. Yeah, well right now we're just running it through the VCR (lol). Looks like we're going to have to get some upgrades... Thanks guys!
Your projector's ability to play 720p/1080i has no bearing on how well it will play content from a VCR.
For HD content a composite cable can pass a weak signal which will cause pixelation.
Now that you say it is from a VCR, I just think your projector can't upconvert very well.
In the early 90's I saw a VCR with projector and it looked fine.
Anyway, yes you need to upgrade.
1 - 7 of 7 Posts
