I think the first thing I would do is quit powering it on, then pull the back and check the power supply for swollen capacitors. If so replace them and check the voltages. Also check the SDR-U boards for blown chips. Since you still have full screen picture and sound before going into standby you may be lucky. Hope this helps.
