1 - 9 of 9 Posts
I have aquired a hi vi sp10 driver, APR 10 PR, and a dayton 500 watt plate amp,looking for ideas for enclosures.I was going to apply the parameters of all components into bassboxpro and see what happens,I am learning quickly about the terminology and how it applies but I am still inexperienced in applications.Looking for ideas and any input would appreciatted.
Here are the specs of my hivi sp 10 and apr 10
VCDIA 3"
LE 1.35 MH
ZNOM 4 OHMS
RE 3.4 OHMS
FREQ RANGE 35-150
FS 34HZ
SPL84 DB 2.83V/1M
VAS .60 CU FT
QMS 4.83
QES .65
QTS .57
XMAX 15.5 MM
APR 10
SD 320 CM SQ
QMS 7
CMS.48MM/N
RMS 3 KGS
VAP 67 LITERS
MMP 66 GRAMS
FP 28 HZ
XSUS 26 MM ONE WAY
MAX MOVING MASS 1200 GRAMS
MIN FP 6.7 HZ WITH FULL 1200 GRAM MOVING MASS
DAYTON 500WATT SUB AMP
273 WATTS INTO 8 OHMS
540 WATTS INTO 4 OHMS
SNR 98 DB A WEIGHTED
EFF 75%
INPUT IMP 12K OHMS
THESE ARE THE NUMBERS OF WHAT I HAVE, IF SOMEONE HAS A INNOVATIVE PROGRAM TO HELP ME DESIGN AN ENCLOSURE IT WOULD BE MUCH APPRECIATTED
I was thinking I was going to need a second APR.Thanks for helping me out.I do have one other concern, the amp is approx 5 inches deep and 10 by 10 inches square do I have to compensate for that?
Steve
1 - 9 of 9 Posts
