Hi all I have been stumped on what is wrong with my samsung and would be grateful if anybody knew what could possibly be the problem
About 4 months ago the bulb went out and I replaced that on my own
Around that time the set started making a loud grinding noise (later found out to be color wheel)
Two weeks ago the set turned off spontaneously. Attempts to turn it on result in the front lights blinking (cant remember which ones it was exactly then) and it just keeps trying to restart itself
I figured it was the color wheel because of the grinding noise problem that it started having and ordered a replacement. Yesterday I swapped the old color wheel with the new one and it still will not fully turn on.
With the set open (I taped down the cover sensor) and the color wheel cover off I attempted some troubleshooting. I found that when I hit power and try to start it up:
-The color wheel spins up and remains spinning, seems to be working fine
-The bulb flashes a few times quickly during the startup attempts so the bulb cant be bad and its only 4 mo. old
-the ballast light flickers a few times during startup also and makes clicking noises
It tries turning on a few times before powering down and showing me all 3 LEDS on front blinking. During the startup attempts only the LAMP light blinks but I'm pretty sure it did that for a few seconds before coming on when the TV was fully operational.
So at this point I just cant figure out what it is. Do you guys think one of the boards could have coincidentally died in the months after the color wheel started making loud noises? I've stared at the wiring for hours trying to find anything out of place but it all looks good to me so I dont think I put it back together wrong.
Any ideas at all would be much appreciated! Thanks
