1 - 4 of 4 Posts
I have a Samsung HLN617WX/XAA 61" DLP and I'm looking for the 5 wire cable (1 blue wire and 4 white wires) that goes from the DMD Board to the Ballast. Just wondering if anyone has any ideas where to look. I don't know the part number or if it even has one. I have checked eBay but no luck there. Would appreciate any help. Thanks.
Plain ole user
Call around to local shops. Someone may have a scrapper.
If you don't have a service manual, you probably can buy one and get the part number. Then see if Samsung can get a replacement for you.
Discussion Starter #4
Thanks for the replies but I finally found someone on eBay that will sell me a set of wires. It took a long time but worth it. I will check my local tv repair shops to see if they have any samsung dlp's that they have parted out. Never hurts to have hard to find parts just in case. Thanks for the help.
1 - 4 of 4 Posts
