1 - 3 of 3 Posts
Having an issue with a HLR5067W. Standard cable has several sets of vertical plaid green lines. This also occurs on the RCA inputs. Local "HD" cable channels have small green and pink plaid squares. Component (480p tested) and HDMI (720p/1080p tested) are working fine. The tv guide and menus are fine. PIP is also fine.
I've had similar problems on LCD power boards before but the capacitors, what few I could locate, looked fine.
Since the HD inputs seem to work fine I'm leaning towards a bad analog board but the TV tuner is on the digital board. Does it bypass straight to the analog board?
Any help with this would be greatly appreciated.
Plain ole user
Common symptom with a bad digital board. It could be something else, but that is my first guess.
1 - 3 of 3 Posts
