1 - 3 of 3 Posts
Hey all, so I own an HLR5067WAX/XAA DLP and recently the screen has appeared significantly dimmer than it use to display. I've also noticed a high pitched buzzing coming from the area of the lamp. I'm inclined that this is a problem with the lamp and that this needs to be replaced but I don't know how lamps typically react so I wasn't sure if this was a different problem.
If this is indeed a problem with the lamp could someone point me towards a location to purchase a new one?
Thanks in advance.
Plain ole user
I agree. Lamp is the most likely problem. I would check the caps on the PS and ballast and see if any look swollen, but the lamp is almost certainly bad.
1 - 3 of 3 Posts
