1 - 1 of 1 Posts
Samsung DLP HLR5067WAX/XAA
Power on, Lamp light (front display), Standby flickers (front display) for a second, then Standby does not flicker anymore (front display), then the Lamp light only (front display) continues to blinks after that, then the Lamp light (front display) turns off, then after that then it goes to Standby/Temp (front display).
Here are the steps.
1. Power, TV clicks on.
2. Lamp lights in the back.
3. Color Wheel I can hear spin up down and up twice (it seems like) and spins.
4. Get illumination on the screen from the lamp.
5. No sound (start up tone) or Menu.
Thank you for your help,
Fred.
1 - 1 of 1 Posts
