Hello
My home studio is a room 2,90 X 3,10 and 1.90 high. wall are stones, ceiling is made of a mix of plaster and floor is 90 % covered by a thick carpet layer.
i wish to kill the natural reverb so i made some absorbers, 6 pieces, 2 per wall. (5cm thick rockwool frames, 135X60) and one wall (the one behind the speakers) is hidden by a "curtain" of OSB pannels (4 pieces 170X64) hanged from the ceiling and covered with foam (4cm thick, the one with spikes).
BUT ! a noise like a HUMMM can be heard when one speaks. I'm going to use REW to identify this but i would like to know if some of you have any idea ?
Is the OSB curtain a bad idea ? Are my absorbers not thick enough ?
Thank you in advance.
L.
L.
