1 - 11 of 11 Posts
After invaluable feedback from various members I've come up with this layout... what do you think
3 rows is a lot to fit in a room that length. 1' between rows isn't enough. Why not do 2 rows of 4? You have PLENTY of walkway width on both sides that could be reduced to allow the extra seat.
Bryan
Bryan
Completely agree - also, putting the rear row on the back wall is going to rather boomy for anyone sitting in that row.
How big is the screen, 9 feet may be a bit close to sit especially if the screen is going to be 100" or bigger. If you are going to eliminate the 3rd row and move things back a bit it should be fine. I too agree three rows is pushing it.
1 foot between the rows will be like sitting on an airplane.
Have you considered a bar in the back or bean bags for front row to gain the number of seats u want?
Bryan
Hello Bryan,
I actually didn't intend on putting in recliners rather I am thinking couches. With platform width at 4.5 feet and the couch at 3 feet I will have about a food and a half left over for leg space. would it still be tight? ... I feel HT will be a social activity and will mostly have friends and family over when we use this. In that case I will need all the seating capacity I can get.
The screen is at 90"X50". I was working through a THX calculation sheet and consulting different forum. It came out that the maximum viewing angle should not be more that 41 degrees... I'm at 45. I could consider a bar with comfy bar stool at the back...
The space is actually 18". Bar in the back... good idea.
absorbers can help some with sitting so close to the wall.
1 - 11 of 11 Posts
