1 - 20 of 25 Posts
Hi All,
I am new to Shack.
I have bought a new property and i need to convert one of the rooms as a HT. This room should serve partly as a living room and partly as a HT so i cannot have a typical HT seating arrangement. I have attached a picture of the room. Dimensions are 21'11x12'10 I intend to use my HTPC to play the media and use my ONKYO 607 as receiver.
Any assistance you can provide me on the below would be of great help. Thanks
  1. I am planning to remove the fire place. What other changes would you recommend in the room?
  2. I am planning to project on the wall along the width of the room. Whats the picture size i can achieve
  3. How far back do i need to mount the projector?
  4. Please recommend me a screen, projector that would be good. Can i get a 4k projector at decent price?
  5. What speakers would i need for a room of this size? I need 7.1 setup
Hi All,
  1. Control light coming in from outside. Projection requires a dark room. The black level you get is limited by whatever ambient light is hitting the screen. For example, those contrast ratios we hear about, like 50,000:1...a guy in the front seat wearing a white shirt will reflect enough light back to the screen to reduce that ratio to 2000:1 or less. You cannot ever achieve the specified contrast ratio in a practical home theater, but 2000:1 is usually good enough. Plan to black out the windows completely if you're going to use this in the daytime and want good contrast/black levels.
    [*]I am planning to project on the wall along the width of the room. Whats the picture size i can achieve
    [*]How far back do i need to mount the projector?
    [*]Please recommend me a screen, projector that would be good. Can i get a 4k projector at decent price?
    For a good start, go here:
    http://www.projectorcentral.com/projectors.cfm
    If your seating results in a controlled viewing angle, pretty much straight in front the the screen or only slightly to the sides, you can use a gain screen to pick up some brightness and contrast, but if you will have viewers in a wide angle to the screen, it's going to be a flat, non-gain screen so they get a decent picture.
    [*]What speakers would i need for a room of this size? I need 7.1 setup
It's less about the size of the room, more about the size of the budget. What do you have to work with?
For that bright a room you will need a screen like this for example
http://www.dnp-screens.com/DNP08/Products/Front-projection/Fixed-screens/dnp-Supernova-One.aspx
4k projector imho are not required for today's source material, and they are expensive.
Since you will need to put your seating against the rear wall to get any distance for a large screen you will have to decide how large a field of view you want.
For Distance consider where you like to sit in a commercial theater. Go see a movie and pace out the width of the screen, then pace out how far back you enjoy sitting, this will give you a ratio that you can transpose to your HT.
http://www.projectorcentral.com/proj...creen_size.htm
The AE8000 on Cinema 1 mode will push out approx 550 lumens with no zoom. The more zoom you use the less light hits the screen. The AE8000 widest angle for a 120in screen is 12ft (numbers according to review on projector central)
You are looking for a FL (foot lambert) brightness at the screen of 15-16 (if you have completely dark room), more if you don't or if you want to view 3D.
using those number and a calculator like:
http://carltonbale.com/home-theater/...er-calculator/
http://hometheaterhero.com/htcalc.html#top
You will be able to calculate the screen gain you need to achieve that amount of light.
As for speakers with an open area to one side and the seating area against the back wall if a 7.1 is wanted I would probably look at in ceiling for the side surrounds (with pointable/angleable internals) and a bipole or tripole rear channel such as the axiom QS series. However, speaker selection is very personal, what one person love another will hate, go out and listen to different speaker brands and report back what you have found you liked and disliked about different manufactures, at that point those that happen to own those speakers may have some insight for you. Additionally, hearing a speaker at a showroom and hearing it in your room they may sound totally different, once you have narrowed it down a bit, ask if you can bring them home to listen to them on a trial basis.
Since this is a multi-function room I'm hesitant to make many suggestions till I ask some questions in no particular order...
1) is this a 1 story building/do you have attic access over the area?
2) are your joists parallel or perpendicular to the wall you want the screen to be on?
3) where do you plan to put your equipment?
4) realistically what's your budget, how far beyond that can you go before you scrap the whole project? IE how good do you want it to look/sound?
5) do you want to see your speakers or are you planning to have all speakers in-wall/ceiling
6) will this room ideally expand out to music/speakers in other rooms of the house?
7) will you be using the projector for all viewing or just "movie night/events"
8) are there any particular WAF issues we should keep in mind?
9) what are some cool things you've seen that you would love to include in your system?
10) how do you want to control the system? iPad/Tablet control, macro based remote, just using a few separate remotes is no big deal...
Given the amount of light in the room and your viewing distance I would give some thought to using an LCD TV along with a drop down screen and projector. You can check projector central calculators but likely you are in the range of a 100 to 110 inch screen.
Another alternative is to use a large LCD TV only with a 70 inch screen or bigger. This will allow the room to be multipurpose and not a cave.
@Gazoink - Thanks a ton for taking the time to provide such a detailed response. Greatly appreciated!!
I am planning use black out curtains for the patio doors and dark curtain for the other.
I am planning to spend around £2000 max for the speakers. What can you recommend?
@Andre - Thanks for taking the time to respond with so much detail.
I need some help here, pls. I understand FOV is what the eyes can see ( i am right? ). If this is right, should i not want the biggest possible FOV? You are right, i need to put the seating against the real wall.
I have done some calculation based on the links you provide, i believe to achieve a 140" diagonal projection i need a screen of 122x68 screen, i need to place my projector at around 12 feet from the project wall? My seating would be 1 row at around 15' from the projection wall. Does these sound right
My question about FOV would answer this but, my wall is roughly 13' wide - Can i see the whole screen sitting roughly 15-18' back?
Ceiling speakers would be too much of a pain for me. I would prefer to mount them on the side walls. In the picture above, where my switch box( white colour ) is where i am hoping to get my side surrounds. Would this be ok?
@rab-byte Thanks for your questions.
The building has 3 floors. This room is on the ground floor. I can install a false ceiling if required to run cables etc on the ceiling.
Parallel
In a cabinet on the rear end of the room. If there are alternative/better suggestions for this, please provide.
Speakers - £2K
Projector - £1K
Planning to use existing AMP Onkyo 607 unless its no good for the project
See through speakers would be good or wall mounted.In wall speakers would be too much efforts to get a builder etc..
It would be really nice if it can do that. But i fear this would be too much money to achieve
We have a main living room where we intend to watch casual viewings. This would be used for movies, sports etc. We watch atleast 3 movies a week
No visible cables. Easy to clean
I am not sure about "cool things" as i haven't seen many but music streaming would be nice. The key aspect for me is the Sound - To be able to deliver really good HD audio would be very important for me.
Easy here - i currently use my iphone app to control XBMC running on my HTPC.
So your budget is around 4k USD... 3k£
With parallel joists you could do a motorized screen that will drop down when in use and roll up into the ceiling when not in use.
If a clean look is what your going for then in-wall/ceiling speakers may be your best bet. Since you're removing the fireplace and willing to modify the ceiling then pulling speaker wire should not be a problem. This will make the system vanish when not in use.
Check out iRule as a DIY control system it has a lower cost of entry and should serve you well if you're planning on using your iPad for everything.
Thanks again rab-byte - Can u pls recommend me some projectors and speakers in my budget? Also what would be the best way to do the following;
* running speaker wires through the wall! Are there special tools for this?
* Running power cables and other cables to the projector in a concealed way?
any recommendations on this, pls?
In-wall in-ceiling speakers are available from several manufactures. Don't know what's available in your area....
Here's a starting point.
http://www.speakercraft.com/products/architectural-audio
I'm a fan of Epsom projectors. Panasonic has some very highly rated ones as well as big names like sony and JVC.
Google electric screens you'll find several. Screen Innovations is a well known reputable company as are Stewart but you can find cheaper also. The thing about a screen is its half of the picture and can really make or break the image depending on the room lighting.
You'll probably end up gutting the ceiling to run your projector and while it's open speaker wire shouldn't be a problem. You already have power up there because if the light fixture/fan... I'm guessing that's coming out.
Ultimately you'll need a drill, drywall saw, tape measure, and something to do wall fishing. I prefer poles to fish tape but both can work.
Good luck.
You may want to read some other members build threads to get some idea of what your getting into. Honestly your budget may be tight but it's doable.
Try to get your hands on a benQ 1070. Should be well under £1k. I am getting the 7500 but have seen the 1070 and they are quite nice. Awesome 3d as a bonus.
As for speakers. Check out the Anthony gallo micro or adiva. They have in ceiling mounts and are very easy to install. They are a sphere shape so stick out but very subtly.
Discussion Starter · #14 ·
@cowboyofclubs - thanks for your reply. BenQ and Optoma are two projectors i am considering. As for speakers my primary concern is choosing a speaker system that is sufficient enough for the size of the room in terms of power. How should i determine this?
Also how would the Anthony Gallo micro compare to something like B&W? Are they le
Discussion Starter · #18 ·
Thanks - My main concern if the speakers will make enough sound to fill the room - how can i choose the right speakers? What am i looking in terms of £ for B&W 7.1?
USD between $2,000-$10,000 + AVR and other equipment. Don't get me wrong they'll sound amazing and hold up for many many years to come. They'll become a part of your home and you'll love them. I have yet to hear a bowers setup not sound great!
Just to add a little bit more to that last statement. Bowers has a very noble pedigree. They're the only speakers used at Abby Roads, Skywalker Ranch, and Air Studios. They are a mature and refined sounding speaker with stunning highs that are not too aggressive and a smooth midrange. When properly paired with the right sub they blend quite well and the woofer will vanish in the room.
Their in-wall/ceiling line is designed with the installer in mind. The brace is installed first, light weight and sturdy, then the speaker itself is mounted into the bracket. Most speakers take about 3-10 min to install and you're holding a 5-10lb speaker the whole time. With B&W you don't tax your arms nearly as much and repositioning the degree the in-ceiling are towed in is easy. Don't underestimate how important this is when mounting 7 speakers!
1 - 20 of 25 Posts
