1 - 4 of 4 Posts
D
Guest
Hi all,
i got a problem with my rear set of speaker's - dynamic wireless speakers system. When they are plugged in the power it's ok. But wen i turn on the main part of home theater the humming begins on speaker's. I tried to click on reset frequency button behind subwofer (box) but it doesn't help(it stops if i hold it). Do i need better cable for interference? Tried another plug but it wont help. Please how can i fix it????
Thnx a LOT.
:wits-end:
Hi and welcome to the shack!
When you said "you tried another plug-in" did you run an extension cord over to the same circuit that the rest of your A/V equipment is running on?
Have you tried turning other things off, like fluorescent lights and other equipment all around the house?
What brand/model are the speakers?
Try disconnecting the cable from your satellite/cable to see if that stops the hum.
D
Guest
Discussion Starter #4
I try-ed everything from turning of light's, microwave, refrigerator...brand=dynamic. II tried "extension cord ". Can it be that its broken? It hums only when i turn on central part wireless..i assume bluetooth.
Thanx for ideas.
1 - 4 of 4 Posts
