Hi,
I am new to these boards- and I am not a very technical person at all.
So, I will try to explain myself as best as possible.I hope you can be patient with me!
Heres the story:
I have a Dvd recorder and also a home theatre system, which also has USB flash drive capabilities(we are using that to play some movies and music).
With the way I have it connected now, the home theatre system is only useful for audio purposes.If you put in a dvd or USB-you can hear the movie but not see it.
The only solution we have come up with is to take out the S video cable (which is currently running from the DVD recorder to the TV) and plug it into the Home theatre system-which then we can view the movies-but then of course the dvd recorder will not work.
I want to be able to have both hooked up so that I have the option to use both systems as I like, without having to constantly unhook things!
Is this possible? What can I do?
Heres the story:
