1 - 10 of 10 Posts
Super Moderator
Does anybody have polar graphs for Yamaha HS8 and Dynaudio BM5Amkii.
Want to compare them with Behringer 2030 and 1030 and many other given here :
http://dtmblabber.blogspot.in/2011/01/review-of-polar-graphs.html
Thanks...
Hi Hifisound,
Possible, but doubtful. In cases like this, I usually do (you may already have done so also) a Google "Images" search for the respective speaker models. The Yamaha drew a blank, with the exception of the supplied on axis data...which is relatively smooth. Of course, we know that tells us nothing about the off, though it appears they use some form of waveguide on the tweeter, which is good.
The Dynaudio revealed this http://www.bonedo.de/artikel/einzelansicht/dynaudio-bm5a-mkii-1/2.html?noredirect=1
Which shows the classic direct radiator HF "flare" around 3k, as expected.
cheers
I too had reached the bonedo website via google
http://www.bonedo.de/artikel/einzelansicht/behringer-b1031a/2.html
Here the if one clicks on the graph, there are many more for other speakers including Dyn BM5A, Yamaha HS50 , Adams etc.
Though I couldn't get whats the blue line for (off axis response for some particular degree maybe)
1031A seems to have quite a good behavior, though if I am not wrong 2031 has the best distortion measurement.
For some reason 1031A suffers in lower mids in THD
Though would have liked to see response at various degrees...
Super Moderator
Yes, I would guess maybe 45 degrees or so. My German is not so strong.:)
I am a bit suspicious of their methods though, because there is level divergence to low frequency. I can't help but wonder if they are rotating the speaker relative to the mic, vs rotating the mic around the speaker on a fixed radius relative to a chosen point on the speaker.
I would be very careful deciding anything based on that sort of distortion data. Actual aural perception of distortions, is complex business. Not cut and dry by any means. Measurement methods and conditions can greatly affect results also.
Indeed, "Pro" manufacturers have no excuse for this. Not today.
cheers
Hi ajinfla,
Any listening experience with the monitors I have mentioned i.e Beh 1031A, 2031A, Dyn BM5A and Yam HS8 ? Would be great to hear your feedback...
I am planning to use them as nearfield( 2-2.5 ft) computer speakers. May add one or two 15" subs later. Also have Focusrite 2i2 and minidsp 2x4.
My earlier purchase (long ago) of living room speakers was based on lot of auditions (have Dyn Contour 1.8mkii)
Though I am happy with that purchase, now taking the measurement based route!
Both Behringers have lot of data on the net as many folks have measured them.
Have kind of narrowed on 1031A for now. But was just checking out data for other options as well.
Adam Artists were also suggested to me, but that is a much higher price bracket...
And also wondering if they really add anything to sound quality, if they measure similar as 1031A
Thanks....
Super Moderator
Hi ajinfla,
Any listening experience with the monitors I have mentioned i.e Beh 1031A, 2031A, Dyn BM5A and Yam HS8 ? Would be great to hear your feedback....
I have some cursory listening experience with some of those, mainly at pro audio shops.
The Dyn's are obviously the upper end of the price range.
Do you have a specific range?
That's pretty near. Is this for monitoring/mixing? Will they be on desk? On console (raised)?
Dual 15's nearfield? Will your playback levels be fairly high?
Thanks....
Measurements are very important. I design strictly by them. :)
However, sitting 2.5' away negates a large amount of what you may be concerned with, namely the horizontal polars. Not saying that are of no importance, but in this scenario, much less so. Unless the speakers are to be placed on their sides (which happens often with "monitoring"), I would actually be more concerned with the vertical directivity.
To skip forward a bit, let me make two suggestions, the latter you may be able to audition in a local Pro shop.
The KEF X300A
The M-Audio M3-6.
Your response my revise this :).
cheers
Max $400 each (BM5As are currently at that price on Amazon.com)
Just music listening. Placement on computer table beside the LCD monitor
That's in future to reach into deep bass level with low THD. Though SPL requirements are moderate.
Two subs if one doesn't give smooth response till 20-25 Hz
Usual vertical placement
The KEF X300A
The M-Audio M3-6.
cheers
Will search for measurement data on these
Super Moderator
Ok, what I suggested is within your budget. Hopefully size range as well.
If the subs are nearfield like the sats, they will be no smoothness issues. A single 15 would be fine.
Ok, then you almost certainly want point sources rather than vertically displaced drivers. And vertical directivity control.
I doubt you will find polars for either. The KEFs will be good. Not sure about the M3-6, but both should sound good in such a nearfield setup. Polars would tell you almost nothing about how they sound from 2' away.
If you can listen to any of these in a pro shop, I highly recommend it.
cheers
Maybe slightly far, about 4 ft. Anyways I would start with one, measure and decide
cheers
Wouldn't minor movements in nearfield result in relatively larger degree of movement, requiring a speaker having wide directivity ?
Super Moderator
Agreed, though 4' is still nearfield, so modal issues at LP should be moot.
Not "wide", but "controlled", like the KEF especially. Point source aids there too. You plan on dancing in seat?:)
cheers
1 - 10 of 10 Posts
