1 - 20 of 23 Posts
These are the speakers i am deciding on BIC America FH6-LCR with horn or BIC America DV-62CLRS with dome? They are both the same price and what i can afford. Only for Home theater and room is 10 x22 and i'm 13' away. Match to pioneer vsx-520 reciever.
EDIT: I noticed the db rating of 95 vs 90 between the two. Is that as big an increase as it seems in volume per watt?
Hello,
I have not listened to either, but would probably recommend the Horn Loaded Model as it will be more efficient. That is it will play more loudly with very little power.
This is especially important when using an entry level AVR as the Power Supply is the area where all Brands compromise and the competition is cutthroat in terms of Consumers looking at Features and Rated Power.
Cheers,
JJ
Make sure that you tweeters match the tweeters on your mains, if they are horns then the centre should also be but dome tweeters do usually have a softer less directional response.
Discussion Starter #5
Well I will be replacing all the speakers. I was thinking about getting three of the center channels LCR.
Posted via Mobile Device
Hello,
The combination of a fairly large room (sitting 13 Feet from Speakers) coupled with an entry level AVR is what made me recommend the Horn Loaded Model. I really think the efficiency issue is an important one with the combination of large room and not a great deal of AVR power.
Cheers,
JJ
Matching your speakers across the front stage is especially important. I personally like the sound of dome tweeters over horns, so i you have the power to feed these particular speakers then that is what i would go for, JJ is absolutly correct with horn drivers being super efficiant and easy to drive. However it also comes down to personal tastes in sound, to me horns just sound too bright where as domes seem to flow evenly and blend well with the rest of the speaker. :T
G
Guest
Have you demoed the two different styles yet? I agree that horns sound more forward, but when movies have whisper moments, horns keep it alive, IMO.
That is not the best plan as turning a centre speaker on its end rather than leaving it long side down as its design will effect the sound. just get a left and right speaker that is in the same line and model.
This depends on the speaker. Many so called center channels are just MTMs with no specific center design.
If its a horn design you cant turn it.
Hmmmm, You maybe right. Personally not a big fan of BIC but that is going to have to be a personal choice. I would go with Klipsch if you want a horn design.
Discussion Starter #15
Both set of speakers are can be used for full L-C-R set up or complete surround. I can get eith type for about $300 for a set of 3. I think the Pioneer has enough juice to go the distance with either set. The larger set has a passive radiator system so i thought i'ld by pass.
My main concern would be the horns being to harsh like metal tweet in car audio. I've always like soft dome sound. Since I don't listen to music on the HT i wonder if my ears wouldn't bleed with the horns.
There really is no local shops so I would buy from the US and pick up. I just got the F-12 sub and am very pleased.
G
Guest
I've been trying to get more information on BIC speakers for some time. What models did you listen too, and what didn't you like about them?
I would expect them to be as good, if not a tad better then the starter Klipsch and Polk speakers found at Best Buy, but maybe I'm wrong on that. I really wish I could demo the horn loaded LCR speaker they have for fun.
G
Guest
Do you have a Best Buy? They have horn loaded Klipsch speakers. You could demo them and see if you even like that kind of sound.
I can't tell you that you will or won't like them, but they won't make your ears bleed or sound like harsh metal. They still sound like speakers, just more sensitive and forward sounding. They will be noticeably louder with the same AVR over the dome BICs you are looking at. If you don't want them to go too loud, just turn it down. You will have a lot more headroom with more efficient speakers to listen loudly, if you want. Even if 90% of the time, you don't care about how loud you can go, the one day you want too, you won't really be able to go nearly as loud with the 90db dome tweeter speakers.
The Best Buy Klipsch and Polks are very close in sensitivity to BICs counter parts, so you don't have to demo the BIC to get an ideal on what to buy.
Discussion Starter #18
i'm off to do just that. Will be back to let you know what i tested and thought. That's if they'll hook them up to my model reciever.
Discussion Starter #19
are you kidding me! no one has any horn speakers - BB didn't have the klipsch in either. Unbelievable! :hissyfit: Looks like i'm gonna have to make a decission so i think i'll have to skip the horn and go with the soft dome tweeters.
Besides volume would you say horn are more or less detailed? Why couldnt i live in the big city.
1 - 20 of 23 Posts
