G
Guest
·I'm trying to fully understand how to best implement a house curve within REW and then use REW to properly equalize the subs response.
First, I've followed Bruce's suggestions:
Now assume the blue line represents a house curve rather than the standard response. Can I simply use REW to move the entire curve up or down within REW using the "Target" control on the lower right side until it intersects nicely (more peaks than dips) with my measured sub response? In this particular case, moving the start of the curve down from its present start of about 75 dB down to about 70 dB would result in the curve more closely intersecting the dips between 40 and 50 Hz. I would then have a lot of cuts to make but no boosting needed.
If so, I would then assume that I could use the "Find Peaks" and "Assign Filters" to adjust my subs response to follow the house curve. Finally, I would export the filters to the BFD and now adjust the volume control (not the trim control on receiver) on my subwoofer to equalize the sound level between speakers to compensate for the cuts made during equalization.
Is this the correct way to implement the house curve?
The following is my unfiltered response with a standard curve.brucek said:Simply put a simple housecurve file into the REW directory. Call it housecurve.txt
A simple one that rises from 80Hz by 5dB until it hits 30Hz would have two entries in the file.
30 5.0
80 0.0
Start REW, select FILE and Load Housecurve. That's it. It has nothing to do with the RadioShack calibration file (other than both files are stored in the REW directory)....
Once the housecurve is loaded you'll see it in the target response.
