1 - 1 of 1 Posts
Make sure you have selected the measurement whose filters you want to export, select "normalise samples to peak value" and use 24-bit or 32-bit for the export. After you import a response you can use the controls on the impulse graph to scale the peak SPL level to a convenient figure.
1 - 1 of 1 Posts
