1 - 3 of 3 Posts
The color wheel on my Samsung HLR5067WX/XAA has bit the dust. There are 2 replacement wheels available, one is for a L6 chassis and the other is for a L3 chassis. Is there anyway to determine which chassis I have without opening the cabinet and removing the color wheel. I would rather wait and do the remove/replace as one procedure.
Thanks in advance
Bob
Plain ole user
Look on the label on the back of the set.
I will warn that my experience with Samsung is that without checking the service web site (which only ASCs can access) to find the proper part numbers, you need to be dealing with a vendor that is authorized or at least will accept returns. Much of the part number info from other sources is often wrong.
I did find something that may be what you are referring to - On the label is the Type No. - AT50L6. Is my "assumption" correct that it is a L6 chassis?
Bob
1 - 3 of 3 Posts
