1 - 1 of 1 Posts
So how far did you guys go to determine placement of your manifold? For those that put a lot of effort forward, did it pay off with good response at the listening position?
I ask as I'm thinking of moving my IB's location. Right now, I have a nasty dip in the 40-50Hz range that I probably won't be able to fix. Now that I have REW running, I'd like to do what I should have done before the first install. Then it's a matter of deciding how far to take it, and which approach I will take to finding a better placement.
So just looking for others to share their experience, pre-install to results. TIA.
1 - 1 of 1 Posts
