1 - 4 of 4 Posts
I am using an alsa plugin (equalization plus crossover) to post process the audio output of my applications (Kodi). See below for .asoundrc file -
pcm.dsp {
type plug
slave {
format FLOAT
rate unchanged
pcm {
type ladspa
channels 6
path "/usr/lib/ladspa"
playback_plugins [{
label "ladspa_dsp"
slave.pcm {
type plug
slave {
pcm "hw:0"
rate unchanged
channels unchanged
Is there a way to direct the audio output of REW to the alsa dsp plugin?
The only problem is that virtual audio cable is for windows. I am running ubuntu (alsa should have been a give away).
1 - 4 of 4 Posts
