Hi Wayne,
Thanks for your input. The First Watt doesn't have volume control, my tube amp does.
So not to take any chance, if not using preamp on First Watt what do you recommend as L-pad attenuator?
To make a fair comparaisons I guess I need to set and measure output voltage to same levels for both amp using REW or MS Win. The software setting will be different from the 2 amps. I also understand that I need to be very carefull on level so not to overload card input, it could fry it. I assume I need to have a dummy load connected and connect from that cable to the card's input, right?
If I decide to put preamp in the signal chain for measuring First Watt, I will need to redo system calibration including this unit compared to the tube amp.
Secondly for my integrated amp, in REW, is it doable to measure distorsion versus different power ratings? I guess this will necessitate a particular jig in this situation.
Thanks!
