1 - 4 of 4 Posts
Hello,
I'm using REW to EQ my sub in a dedicated 2 channel system.
My room is largely rectangular but each wall is a slightly different length - is there a way to model it in REW?
Thank you!
Thank you,
Apologies - I'm a NOOB, I meant how can I use REW room simulation with an a-symetrical room?
I noticed you could also enter room dimensions i the EQ filters screen - i wonder if that will improve the quality of EQ? Thank you!
REW Author
The room dimensions on the EQ page are used to show modal resonance lines, they don't have any effect on the EQ.
If the room you are trying to simulate is close to rectangular you could try using the average dimensions. A measurement will tell you whether the predictions are anything like reality.
1 - 4 of 4 Posts
