How To Properly Set Up Your Sony PS3 as a Blu-Ray Player
120572 Views 32 Replies 18 Participants Last post by  dangerbeard
13
Sony's PS3 uses a menu interface called XrossMediaBar (XMB™). Along the horizontal row are the categories and the the vertical rows contain the sub menu items.
You'll want to navigate to 'Settings' in the Horizontal row. Then navigate down to 'Video Settings'. There are several items that will need attention here. We will list each and our recommended setting.
Video Settings
BD Internet Connection
When you put a blu-ray disc in, your PS3 will connect to the internet to look for updated content for that particular disc.
Recommended - Allow
BD/DVD Cinema Conversion
If the video content has been recorded using the interlaced format, this option allows you to select how the PS3 will convert the content. This will mainly apply to DVD content. Automatic will allow the PS3 to detect and select the best conversion mode automatically.
Recommended - Automatic
BD/DVD Upscaler
Content that has been encoded using the standard definition format can be upscaled. But which one to choose? There are four options here. Off is self explanatory. Double Scale will double the horizontal and vertical resolutions. This can result in a softer, blurry look to the content. Full Screen stretches the content to fit. Normal will set the conversion to match your screen size.
Recommended - Normal
BD/DVD Video Output Format (HDMI)
One of the settings under this menu item is labeled 'Automatic'. Normally you would think that this would be the best option but in this case it isn't. There have been reports of the PS3 having difficulty determining what the color space should be set to. Therefore it's best to set the color space according to the display you are using - RGB for a monitor and Y Pb/Cb Pr/Cr for a HDTV.
Recommended - Y Pb/Cb Pr/Cr for TVs, RGB for PC monitors.
BD 1080p 24 Hz Output (HDMI)
This relates to the frame rate or refresh rate of your display. Blu-ray generally delivers 24 frames per second. But your display may not support this rate. Therefore it's best to set this option to 'Automatic' and let the PS3 decide what the best option is for your display.
BD/DVD Dynamic Range Control
This control concerns audio, particularly when you are watching a blu-ray at a low volume level. What it is supposed to do is boost the dialogue portion of the sound. However it has been found to boost other portions as well. Therefore we recommend leaving this option 'Off'.
Recommended - Off
BD/DVD Audio Output Format (HDMI)
Recommended - Linear PCM (PS3 Fat)
Recommended - Bitstream (PS3 Slim)
BD/DVD Audio Output Format (Optical Digital)
Display Settings
Navigate out of Video Settings and go down to Display Settings.
RGB Full Range (HDMI)
Limited conforms to the HD video standard, 16-235.
Recommended - Limited
Y Pb/Cb Pr/Cr Super-White (HDMI)
This setting will give you deeper blacks and brighter whites if your display supports a Y Pb/Cb Pr/Cr signal via HDMI. Even if your display doesn't it won't cause any undue effect.
Recommended - On
21 - 33 of 33 Posts
Well finely finished the Move to Navarre Fl. and competed the million chores needed doing in the new place. I bought a new TV. A Panasonic ST60 60 inch Plasma. I reset the PS3 slim to these settings and it is great.
Thank You one more time I'm a happy camper.
Thanks a ton for the suggestions! One quick question though. I have audio and video output via HDMI from my slim PS3 to my TV, and then I use the TVs optical audio out to my 5.1 Yamaha receiver. What would be the best audio settings for this setup?
2 possible options here.
1st if your Yamaha has HDMI then I would pass audio and video though it.
2nd if it does not then you should go into audio settings and set primary audio to optical. If you don't do this then your optical will only pass stereo and not surround.
Oh OK, I guess I will have to leave it as is for now, my receiver only has two optical audio inputs and I use one from my computer and one from my TV. After I get my home theater setup I will only have my PS3 (until I upgrade to a PS4) and my computer so I will be able to have each one using optical audio out. Thanks!
Great information here - thanks for posting it.
Anyone found a good comparison of the new PS4 bluray player to the PS3 or standalone players like Oppo's $1k units?
I haven't found an official comparison, but I did a comparison at a friends house who had both a PS3 and a PS4 connected to his projector and watched scenes from the same Blu rays on both and honestly I couldn't tell a difference. However, that could be because of his projector just being 720p (BenQ W770ST).
Did you notice any differences in load times or spin noise?
Unfortunately we didn't pay any attention to load times and as far as spin noise the systems were about 15 feet from where we were sitting so I couldn't really hear either one.
Does the PS3 stream Amazon prime video in 1080p and DD+.
I don't see where it says it's 1080p and DD+ streaming?. I'm looking at upgrading from my PS3 and was wondering which blu ray player can. Maybe the PS4 can.
21 - 33 of 33 Posts
