If you have the budget, I highly recommend a MiniDSP. It gives you a ton of flexibility - and you can accurately set the filter down to the hz, and pick the slope........ And adjust it on the fly.
Since the PE BASH500s already have an HPF, I would make sure you understand what HPF setting they are set for before introducing additional filtering. Older ones had a higher default HPF while newer ones supposedly default to a lower (and generally more useful) frequency.If you have the budget, I highly recommend a MiniDSP. It gives you a ton of flexibility - and you can accurately set the filter down to the hz, and pick the slope........ And adjust it on the fly.
Actually, in re-reading the original post...Since the PE BASH500s already have an HPF, I would make sure you understand what HPF setting they are set for before introducing additional filtering. Older ones had a higher default HPF while newer ones supposedly default to a lower (and generally more useful) frequency.
The OP has built two sealed enclosures each with a BASH 500s.This was from a post in 2010, not sure which version it applies to:
The 500W Parts Express has 2.55dB of boost centered at 36.2Hz with a F3 of 29.5Hz in it's default configuration. And it's believed to have a second order rolloff.
