1 - 2 of 2 Posts
hi
i have got the dali ikon 6 mk2 speakers for fronts
dali vokal centre
dali zensor 7 as rears
dali zensor 1 as additional rears
and 4 dali alteco c1 atmos modules
a denon 4300 amp
a crown xls 1002 power amp
blue jeans speaker cable
i have decided to go with a hsu sub but in peoples opion what would be the best partner
HSU subs are not bad, but even in their flagship they are still using an older BASH amp. Seems like the drivers have gotten a bit of an upgrade over the years though. Looks like with your speaker setup you're going to appreciate something that hits hard but stays composed.
I'll tell you, I was really a believer all these years in the power of a ported subwoofer because of the boost you get down low near the tuning frequency of the port. I've been converted, I love the tight sound of my sealed subwoofer. But I did get a rather stupid huge subwoofer, it overcomes the usual problem of falling off a cliff under 20 or even 15hz due to it's 4000 watt amp and 4 18's. You don't have to get that ridiculous to get the same sound though, I'd check out Power Sound Audio. Look at their dual-opposed 15's or 18 sealed models. They will match very well with any setup out there I feel, music or home theater.
1 - 2 of 2 Posts
