1 - 10 of 10 Posts
Ok Guys,
Heres the issue I have, in the next few months I am going to puchase a new projector/plasma for my theatre room. I keep getting different opions from friends and sales men :-( regarding which way to go with this one. Basically at this stage Im tossing up between a Panasonic PT-AE4000 projectors setup Vs Pasanocis 65" Plasma TH-P65VT30A or TH-P65ST30A (Not sure really what the difference is between these panasonic plasmas). I use my theatre room for the following things, I watch sport, play qiute a lot of games (PS3 & Xbox360) and watch BluRays. Here are the things I want this thread to focus on. Due to the size of the room I have the largest projector screen I can really fit in is 100'.
Basically I want this thread to firstly give me a bit of help in choosing either of my options. I am worries about the following things
1 - Motion Blur - Obviously the larger the screen the bigger an issue this gets. Is it s deal breaker for the projector especially when playing games and watching sport etc or is the plasma just as bad
2 - Picture Quality - Can the projector on a 90 - 100" screen get close to the plasma on this front?
Thanks for all your help and thoughts, hopefully you guys can make this an easier choice
Brandon
Hello Brandon! :wave:
What's the room like? Can you control the ambient lighting? What color are the walls? Are they dark? Remember that is you get a pj you have to get a screen, either diy or commercial, as well. Also keep in mind that the step from a 65" screen to a 100" screen is huge. If you are able to control the lighting and light reflections, there is no reason not to go with a projector/screen setup. :T
Hi mechman thanks for the quick reply. The room is a dedicated theatre room which can be darkened the walls are daily light coloured though and the room is about 6m x 4m. What are your thought on motion blur during gaming etc on a projector though?? Thanks
Discussion Starter #6
Am I looking at a decent projector if I have no interest in 3d then guys or are there better options out there now?
I went from a 58" plasma in our theater/multi-purpose room to a projector that throws a 100" image. I built a DIY screen for well under $100. The experience on a 100" screen is far superior. We watch sports and have had people over for big events. I've never noticed motion blur; however, I have not gamed on this set-up. While the picture may not be quite as pristine as the plasma, it is very, very close. Everyone is impressed when the see it. I have an older model 720p Mitsubishi DLP (HC1500).
I went for a 70" LED in our media room and love it so far, I have never been a fan of projector setups, too much noise, wiring and, to me, not as good a picture. I could well be wrong but that's been my experience so far and could not be happier with our new tv. Just need a sound system now.
Discussion Starter #10
Hi therick83 what tv did u end u getting. Have u gamed on it at all? Just want to know your thoughts on the unit. I saw sharp have a 70" but have heard mixed reviews regarding sharps? Thank
1 - 10 of 10 Posts
