1 - 4 of 4 Posts
J
Guest
Hello!
I have used the DVI -> HDMI from my Radeon X1600 Pro to connect to an X Series TV at 1080 and was less than impressed with the picture quality. Can any one offer suggestions as to what would be a decent video card for this purpose?
Cheers :wave:
A
Guest
Discussion Starter #2
Hello!
Cheers :wave:
You should be able to get as a good a picture out of the X1600 as you would any other card. Was it running at native resolution? It may also be worth trying a VGA connection. Was the image quality bad even on the desktop or only when showing video?
If you still want another card I'd look at an nVidia 7600GT.
J
Guest
Thanks for your reply!
I was justing running the standard windows desktop in the native resolution 1080. Edges of text appeared blocky and some colours (such as folders) off colour. I changed the TV colour settings but these seemed to have minimal effect.
Am looking at a new card for the HTPC and agree with your recommendation :jump:
Definitely an Nvidia with the advance DeInterlacing and stuff. There are some 7XXX series that have HDCP DVI ports if your ever thinking of doing Blu Ray or HD-Dvd drives.
1 - 4 of 4 Posts
