First off, koyalo, welcome to the forum!
Yes, the mix series that HTS-X2 is a part of (to be called Elektra™) will run from N8.5 down to perhaps N7 (the bottom end is yet to be determined). It will be based on simply adding differing amounts of N6 gray paint to Cream&Sugar™, the more N6 paint added the darker the mix will be.
If you want a reflective N9 screen mix, this is already available in Cream&Sugar™. Check out it's thread here.
The amount of N6 paint to add to C&S™ to get Elektra™ N8.5 has yet to be determined, but it will be something close to only 1 or 1.5 fl. oz. per 48 fl. oz. of C&S™.
Please keep in mind that this thread is in the Developers Forum for a reason - the mixes are still in development.
I haven't had the N6 paint matched in Valspar paint yet, but I understand that Lowe's should have no trouble making it using the Behr tint formula, it all depends on the person behind the paint counter at Lowe's.
Are all of your walls in the projection room painted white? How large is your screen?
Your PJ is a bright one so more likely than not a N8 screen would work for you depending on how large your screen is.
And we appreciate your taking the time to inquire into our screen mixes. :T
