I have Sony SS TSF500 (3 ohm) speaker and Onkyo TX-SR444 connected, the problem is there is not much audio volume coming from the speaker. To check if it was speaker issue, I replaced it with another 3 ohm speaker but the result the same. Also I reset the Onkyo AV incase there was some setting issue.
I want to know if it was safe for the amp if I serially connect two 3 ohm speakers and would it produce a good output rather than a low volume when connected individually.
Any and all help is appreciated.
