1 - 4 of 4 Posts
Is the smoothing the same for both traces? I can't read the legend clearly; 1/3 vs 1/6 maybe. That would make it look different.
No, it's not normal so there is a difference in either the measurement or in REW settings someplace. I assume you confirmed that the different result is repeatable with both java and ASIO.
Maybe if you post a .mdat file we could help check some basics as to the REW settings. [I think you will may need to use the post padding thread to get to 5 posts before you can do that?]
If we are sure, all measuring conditions and all REW settings are identical then we are mistaken. :)
1 - 4 of 4 Posts
