1 - 5 of 5 Posts
I have 2 mtx tp212 speakers and I am looking for a good receiver. My budget is around $500ish. Thanks
Hello,
Welcome to Home Theater Shack. For around 500 Dollars, you can get a B-Stock Onkyo TX-NR807 (1100 MSRP) from Accessories4less:http://www.accessories4less.com/make-a-store/item/ONKTXNR807/Onkyo/TX-NR807-THX-Select2-Plus-135-watts-Channel-7.2-Network-Receiver/1.html
Here is the Overview of the 807:http://www.us.onkyo.com/model.cfm?m=TX-NR807&class=Receiver&p=i
If you have problems with buying refurbished units, Amazon is selling the HT-RC180 for about the same amount:http://www.amazon.com/gp/product/B002L6GEKG/ref=s9_simh_gw_p23_i1?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=1FXDMPY4FQQPJZQRXEJ9&pf_rd_t=101&pf_rd_p=470938631&pf_rd_i=507846
The 180 is based off the 807, but has 1 less HDMI Input, no 12 Volt Triggers, and a few other things. The 180 is available at AC4L for 429 Dollars as well.
Here is the Overview of the 180:http://www.us.onkyo.com/model.cfm?m=HT-RC180&class=Receiver&p=i
Cheers,
JJ
You say you have two speakers; is that going to be it? Is this going to remain a two channel system or are you eventually going multi-channel?
If you are staying two channel and don't need AM/FM, the audio DAC or video processing found in the typical AV receiver perhaps a good integrated amplifier would suit your needs.
The Harman Kardon HK3490 is a feature-rich stereo receiver that should be considered.
1 - 5 of 5 Posts
