1 - 20 of 48 Posts
iam looking at 3808 , dennon ,pio elite o3 sc o5 , nr 906 onkyo, and any good yamaha like 1800, 3800, i like to match my iq5s to it with 1qc6 and for rears i think def techs any one have any comments please feel free to post them thanks
Re: i need a new reciver
I would have a look at the Onkyo 906. Its got allot going for it including the Reon HQV video upcscailing.
i like the pio and dennon never seen the onkyo in person cc doesnt have it so i wont know how it sounds yahama had one i like the sound i ahve one ? are my speakers warm nautral sound or bright like klipch i need to look for the rears any suggesting iam looking bp def techs for rear since iam going to put them on the wall
...i need to look for the rears any suggesting iam looking bp def techs for rear since iam going to put them on the wall
I read that is best to use the same speakers all around the room, if the iq5s are to big, I probably look for smaller speakers from the same brand and model if possible; combining different brands is okay (specially for surrounds) ...but I prefer to have all speakers from same brand at least :bigsmile:.
The Onkyo would do a great job. I find that Onkyo's are very flat they add little color to the sound. Yamaha's are a bit warm (not that that is a problem) its just what I hear as I have both Onkyo and Yamaha.
wht about pio elite sc05
I have never owned Pioneer equipment but have heard owners do like them.
If it were me, I'd look at the Onkyo 805 rather than the 906. I don't think you're going to get that much more with the 906 and you'll save a few benjamins with the 805.
I think anything in the same price range by Denon and Yamaha would do well too. Onkyo does seem to offer the best features for the price right now though.
I don't have anything to back it up, but I've heard that Pioneer has som realibity issues and may be overpriced for what you're getting.
as for the speakers, I think your center is a good choice -- a bookshelf from the same line I think would be even better. As for the surrounds, I really believe that the ideal is to get the same speaker for all the speaker in your system. Barring that, speakers from the same product line is the next best in my opinion. Given that, I'd probably steer away from a DefTech speaker as a general rule.
But all that is just my opinion.
Either receiver will do fine, 110 watts is plenty of power. Enjoy.
you have any recomendations on 110watts receiver or 130watts 0r 140 watts and i want something tht not going to get so hot like 604 ihad 888 dennon and ijust got warm i heard the yamaha doesnt get hot just warm so if u tell me with ones are just fine without the heat issue thanks p.s iam looking dennon and yamaha and pio elite sc 05 wiith has ice power and it sound incredible more detali but still thinking about it since i also want to buy new tv lcd or plasma .
so i need to buy expensive receiver tht does 140 watts or 130 watts *7
I always say the more power the better but any of the receivers you have listed above will do you just fine. How large is your room?
110 watts is more then enough power. You will never use even that much unless you want to get evicted by your landlord for being to loud.
The difference between 130 and 140 watts is imperceptable, both in output and quality of output. There's more to quality than the amount of watts. Also, wattage numbers have become a marketing ploy. The numbers are rarely put in context. For instance, I have an NAD T762 that they rate @80watts, but others would probably rate as 120 watts. I tried a digital amp (Panosonic), rated with half again as much power. The NAD sounds much, much better.
Doug
1 - 20 of 48 Posts
