[/B][/B]Finally, I successfully get the signal in all channels with NanoAVR-DL by changing the system setting in NanoAVR programmer from auto to 7.1 channel.
Now, after many attemps or trials, I never get enough input level to get the first mic. Position measured.
I followed the manual instructions many times and get the message: level too low every times.
I raised the volume in the receiver to the level required to get 75db on Galaxy sonometer.
I programmed a remote to raise the nanoAVR volume to 0.
I pushed the output volume control in Dirac Live to -7,5 db, my speakers began clipping but still got the message level too low. I also made many test with different input gain.
The UMIK I have is from MiniDSP. I put the 90degree file. The mic gain is 18db with it in Diraclive.
What do I do wrong?
Thank you
What do I do wrong?
Thank you
