1 - 4 of 4 Posts
i just resently tried the
J-Tech Digital 4K 60HZ HDMI Audio Extractor Converter SPDIF + 3.5MM Output supports
HDMI 2.0, 18Gpbs Bandwidth, HDCP 2.2, Dolby Digital/DTS Passthrough CEC, HDR, Dolby Vision,
HDR10
and i had to return this because it didnt accept my vizio m55e0 with the full uhd color mode on
when connected between the tv an my nvidia shield with the shield is set to 3840×2160 yuv
4.4.2 12bit at 60hz bt.2020
this is my prefured mode
an im lookin for one that can pull dolby an dts to optical with out the same problems
does anyone have advice
oh an the reason i dont use my vizio m55e0 optical output passthough is it sucks it stutters the
audio in bitstream mode
none of the hdmi inputs ports work on my receiver work anymore an even if the did the 4k pass thought only goes up to 30hz
Discussion Starter #4
i was thinking about using the Comprehensive 4K HDMI Audio Extractor B&H # COCPAHDA3 MFR # CPA-HDA3
i just dont know if it will work with the vizio m55e0 with the full uhd color mode on
1 - 4 of 4 Posts
