1 - 4 of 4 Posts
So i have 4 AE 15s in two manifolds powered with BASH 500 for each pair.
I took some SPL readings relative to Frequency with volume set to 50 on my receiver,and was curious if anyone has advice on smoothing the response or maybe sound treatment. Ironically i ran an audessey calibration as my Denon 4311 does sub correction. Im noticing a dip at 50hz but my crossover is set at 60Hz to some Golden ear T7s.
F SPL
20 90
30 94
40 91
50 86
60 94
100 92
The other issue i have is that i cant seem to get anymore than 110dB at 20 through 30 hz in a 1800cu ft room. Im not sure if this is about right given the 4 15s are being powered with 250 wrms each? Whats also odd is that the subs are in a utility room in front of me and when i open the door, the output actually goes up by 2dB. Any ideas?
Thanks Kal
My manifolds are 7ft apart from each other, directly facing me as a stereo pair. Im 18ft from the manifolds.
I'd say when the is open, the room size changes, so you find a peak at the LP. If you close the door, you'll likely find the same 2db spike, but in a different location. (Or the closed door puts the LP in a small null)
1 - 4 of 4 Posts
