It has to vent into the main listening room otherwise you will lose the benefit of a ported design. Consider the port as an extra driver...(where should it fire?)
Yes, why not. Just take a printscreen, edit in a drawing program like then post.
It has to vent into the main listening room otherwise you will lose the benefit of a ported design. Consider the port as an extra driver...(where should it fire?)First, can an LLT's port, or ports, go into another room of the house, or does it have to vent into the main listening room? The 'other room' would be the basement and the very same room the IB will backwave into.
Yes, why not. Just take a printscreen, edit in a drawing program like then post.Second, can Google sketchup diagrams be used in this forum?
Perfect. So what I'm going to do is go ahead with the IB but figure out what ports would be required if it doesn't work out as IB and install bracing/supports to be able to cut the holes and put the port or ports in.45 and 90 degree elbows can be used with no problems.
Thanks. Upon further review, I might have a problem using Tempest-X. For the initial IB build, two is the max I have room for, and two would be much preferable to just one. However, if the IB doesn't work out and I close off the backflow end and make it into a box, the volume will only be ~500 liters. Maybe enough to qualify as LLT for one Tempest X, but not Large enough to make LLT for two. Vas is 324 liters.Because IB's don't have the "air spring" effect of a normal sized sealed box, or the loading of a port, excursion is always the limiting factor.
If you add up the thermal rating of a bank of IB drivers, it's usually quite a lot higher than the actual amplifier driving them.
110dB isn't a lot really.
Here are some designs for 2, 4 and 6 tempest-X IB's
