Hello everyone,
After years of reading about all the great projects on this forum, I've decided to jump off the deep end. I went out and bought myself an A-lens, decided to build a DIY curved screen, and, lastly, upgrade my low end bass.
To that end, I've decided to try and do a 4 x IB318 setup. My plan is to install the drivers as a line array in a converted closet (the soda fountain in the pictures below will be moved). My problem is that the closet is only about 7,000 L, about ½ the of the required 15,240L to get to 10x Vas. However, the closet connects to an unfinished basement through an opening that is 12" wide by 105" tall by 58" deep.
The reason for this small opening is that a wet bar was built into the closet area. I'm really hoping I don't need to demo the bar. I'd much rather just cover it with a curtain. Also, the ceiling in the closet is unfinished and opens (very narrowly) to the ceiling in the theater room. My question is, will the closet opening act as a vent (and mess everything up), or will I be able to get a true infinite baffle sound?
Thank you in advance for your response.
