1 - 20 of 20 Posts
M
Guest
I have started a dedicated HT and have a few questions.
The dimensions of the room are 15Wx20L. The projector most likely will be placed 9 feet from the screen. I have the flexibility to go as big as I want with the screen.
Here are my questions
1. What can I expect to get out of a projector with that short of a distance.....or that distance not that short? Would I have to get a short throw lense?
2. What would be a nice screen size for that size room?
Help. Thanks:reading:
We can all toss you some suggestions as to what we like for screen size, but ultimately it will be your decision. I would suggest reading Your Projector Screen: How big should it be? from Projector Central. Generally I would suggest to be able to sit from the screen at least 1.5 times your screen width. Screen width is 84" (7')... you would want to be at least 10.5' from the screen.
Throw distance will be determined by which projector you choose. 9' should give you plenty of flexibility though. If you look at projectors at Projector Central... for instance the Panasonic PT-AE2000U ... notice down next the "Throw" you will see a small icon...
... Click on that icon and give it a few seconds to load the Throw Calculator. You can experiment with throw distance vs. screen size.
2nd that on the ProjectorCentral calculator. I used it extensively.
Depending on seating distance and room obstacles, you should do fine with anything between 92" and 120" My room is 11' wide, 92" screen, seating distance or around 9' (front row). Even from the back row (15' back), the screen looks great.
A general rule of thumb to remember is that the farther you have the projector away from the screen the less bright it will be. That calculator mentioned above is a must use when designing your placement of the projector.
If this is your first projector and screen, my advice is not to go too small on the screen size..
I first started out with a 96" screen, thinking that would be plenty big enough..
Three months later I changed it to a 106" screen, and then further down the track to a 120" screen.
A big screen gives you that real theatre feeling and you feel very much a part of the action...
M
Guest
Discussion Starter #6
thanks a ton for the answers. I visited my theater guy today and he said I should seriousely consider moving the projector back to 12-15 feet.
This will be very difficult as a soffett runs right throught the theater at that point.....so rather then have the projector place in the soffett (nobody will see it), it would have to be on the other side (wouldnt make a pleasent site).
I went to projector central and it appears only ONE projector can truely accomadate the 9 foot throw with a 100+ screen size. This could be an issue
Well... again, this is what I meant by we can all toss you suggestions, but it will ultimately be up to you and what you will like and based on the projector you choose.
Many of the projector gods (so to speak) advised me not to use more than 110" screen with my new Panny PT-AE2000U and preferably stay at 100" or less. Supposedly, with my PJ, when I start to get larger, quality goes down... as is the case with some projectors. I'd say the Panny 2000 is one of the better projectors. However, that quality difference may not be noticeable to some as much as others.
Personally I cannot imagine going any bigger than my 97" screen in my room. I've actually considered making it a little smaller at around 92", just to squeeze out that extra tidbit of performance as well as make my screen a little more fitting to my room. 97" is just soooo big to me, it is sometimes more than we really need.
I would try to view various screen sizes in a room equivalent to yours.
You are right though... 9' doesn't appear to be as good as I originally thought. I would only be able to get a 91" screen with my 2000 and that is at full zoom.
Australian Contingent , Platinum Supporter
I know how you feel Mavo... for me the projector is the "last great unknown". I'm still annoyed I can't get a native 2.35:1 projector!
One thing I can add: if you're thinking of adding an anamorphic lens at any point, a short-throw ratio may produce some unwanted keystoning (usually something only a curved screen can rectify). So long-throw is your best friend, in this case...
Just something to add to the mix :bigsmile:
M
Guest
Discussion Starter #9
I measured today and it appears I can place the projector between 10-12 feet.....within the soffet. This to me might work but I need to research at projector central. I also determined that my max screen width can be 95" which would put the heigth at 53"......for a 16:9 ratio
I will attach pics tonight:jump:
M
Guest
Discussion Starter #10
the first photo is of the back wall where the screen will go, second pic is of the problem......soffet
How wide is the wall your screen is going on?
It looks like maybe your front wall there may not be all that wide... is there a closet or cabinet going on the left side?
M
Guest
Discussion Starter #12
I have two false walls in front of the screen wall. I have centered the screen between the two false walls allowing for 1ft inside of each false wall. Cabinets and control room for the house is on left, that is the smurf tubing you are seeing.
In all reality short of the Projector limitations the choice of size is yours. However, SMPTE did alot of work on viewing angle to find the ideal viewing conditions in theatres. They found a field of view of between 25 and 35 degrees and a sweet spot of 30 degrees.
You can be too big for good viewing. This is dispite our natural wide field of vision, the issue is our focal area of view which is quite narrow.
Our area of attention is small.
Some rough figures to get the idea.
Seating is based on 10 feet from screen 16:9 ratio
(to the nearest inch)
25deg = 61in diagonal
30deg = 74in
35deg = 87in
Again personal choice and these are SMPTE guidelines.
The reason you can't find many projectors doing a short throw wide is because of the these guidelines.
Personally I would be thinking 90in max.
An issue with short wide throws is that the optical path will use the outer parts of the lens, quite often not perfect and you can have optical distortions. Especially if you have to use alot of lens shift.
regards
A friend of mine who went to film school taught me a good trick:
Sit at your ideal seat location (usually picked due to room layout or acoustic considerations).
Hold your hands out in front of you as far as you can. Touch the thumbs together and spread your fingers.
The distance from pinky to pinky is close to the ideal screen size in terms of field of view.
I did this in my theater and came up with a 92" screen and 9' seating distance.
The reason it works is that hand size and arm length are usually proportional. If you have giant hands and stubby arms, it might throw off the calculations :D
It also works to try and find the best seat in a theater, not that I've been to one in years :)
Hi.Am i right to say that you mean the tips of the thumbs and not side by side. And the 92 inches is the Diagonal .I used your method to calculate screen size. 6 feet wide Diagonal around 77inches at 9feet 6 inches from the screen .I have read on home cinema forums if you get to small a screen you will wish you had gone next size up. It is starting to drive me mad ,To small a Screen Wish i had gone bigger ,to big eye strain. You cant win .Gerald
My approach to this is to apply some really easy math. If you take the room length and divide it by 3.68, you have actually found the largest (tallest screen) for that room. You take the height and times it by the aspect ratio you want to find the width.
I'm new to this forum but was also wanting to prewire. I think I'm going to buy the Panasonic AE-2000U. I used a projector people calculator to determine throw distance and was wondering how much the zoom comes into play. I figured the quality went down, but didn't know if there was an average or standard used. I think the room is 18-20 feet long. Does height really matter that much? Aren't projectors always mounted about a foot or two from the ceiling?
thanks.....
Just make sure the screen is not so big that you're constantly turning your head to keep up with the movie. Unless you're into that.
If your having to turn your head, then you are way too close. Even when seated at 2x the image height with my CIH 2.37:1 system, the screen is not large as to require head turning.
1 - 20 of 20 Posts
