1 - 10 of 10 Posts
Room is about 17' deep. I have two rows of seats on a platform. The farthest I could place a seat is at 16' and it needs about 2.5 3' for the 1st row. I certainly don't want to be any closer.
And so given that I know where I want the seats I'm trying to determine how big the screen should be before being too big.
I'm sure the guy who I hire to set everything up will figure out the audio. I can barely plug in a lamp
Plain ole user
The screen size depends a lot on your personal viewing preferences and the projector resolution. Where do you sit in a movie theater and what projector are you using?
epson 1080p Pro cinema
I usually sit in the middle of the theater.
I brick and morter guy told my 88" is more than enough and won't cause me to be moving my head back and forth to see the whole screen
Plain ole user
That seems small to me (I tend to sit in the middle of theaters as well), but I tend to prefer a larger screen, particularly for a theater. I suggest you sample a similar distance on a similar sized screen and decide for yourself. My guess would be that your salesman has a screen in inventory that he wants to sell in that size.
There are several screen size calculators online if you google it. You will find different recommendations from SMPTE and THX, for instance. The bottom line is, preferences vary, so you need to get some viewing experience yourself.
In the years of installations that I have done, I have found that few clients are unhappy with larger size screens.
There are several screen size calculators online if you google it. You will find different recommendations from SMPTE and THX, for instance. The bottom line is, preferences vary, so you need to get some viewing experience yourself...
Here is some numbers according to THX for a 16:9 screen...for 13' distance you need a 101.4 wide or 116.3 diagonal screen; for 16' distance 124.8 wide or 143.2 diagonal
You can use your wall to project the movie to choose the right size, then buy or diy your screen :yes:
In our last HT room, our first row was at about 11' with a 97" diagonal screen, which is about 89" wide. I liked it well, but a larger screen would have been okay too. I plan to go a bit bigger this time around with the new HT room... and I should be about 12' back. I am thinking 16:9 will be about 92" wide and the 2.37:1 will be about 123" wide.
17' room should have ideal first row seating at approx 10.5' from the front wall to ear position.
At that distance and your wanting a larger screen preference would tell me that something more like 100" would be preferable.
Keep your rear row as far from the wall behind it as you can for best bass smoothness and best surround experience.
Bryan
1 - 10 of 10 Posts
