Hi all. Not sure what to say other than I'm trying to get into this thing called home theater. My 1st was boughten used for $40 at a pawn shop. Boy, that machine was good and loud. It broke down pretty quickly afterwards; the volume distorted the picture. So, I bought a cheap Duraband to try to replace it. Soon found that if you don't pay out the ears for one of these things it isn't worth buying. Got a $100 effort as a temporary piece, but it died in 6 months after I bought it. Now, I have an RCA reciever that works pretty well for $160. I use the speakers I got with that 1st machine I bought, which are far better than those that came with either one. Thing is, the subwoofer that came with this new one claims to be 8 ohms but it doesn't put out as much power as that used one. Even with the used one's subwoofer it still isn't good enough. I thought about using both, hooking 'em both up, but heard that that's not such a grand idea.
Well, it'll probably be a while till my next post seeing that I don't get much time on the internet these days. But I hope I'll be welcome here. And since I'm a novice, I'm pretty ignorant to all of these terms I've read here on these boards. Hopefully you guys'll be patient.
See ya later
Moviefanatic
See ya later
Moviefanatic
