1 - 4 of 4 Posts
I have successfully made more than 5 posts.
When I attempt to use the IMG tag, it does not work. For example, when I replace any << with an open bracket and any >> with a close bracket (I have to replace brackets to demonstrate for this post so the line isn't hidden) for the following:
<<IMG>>--http://www.hometheatershack.com/forums/attachment.php?attachmentid=78401&stc=1&d=1421881043<</IMG>>
Nothing appears. Any idea why?
I see it just fine.
It can take up to about an hour to update your account after you make that 5th post.
From the rules:
Once you have 5 posts you will be able to fully participate at Home Theater Shack.
YOUR ACCOUNT WILL BE UPDATED WITHIN AN HOUR AFTER YOUR 5TH POST.
It is working now.
I was expecting that (a) posts made prior to achieving the required 5 posts, and/or (b) posts made during the roughly-1-hour window after achieving the required 5 posts, would automatically be updated to show images once my account was cleared for image posting.
Apparently, images can only be posted once a user actively submits an update to a post made prior to the user's account being cleared; thus my confusion. I had to go and edit, and re-save, the posts with images in order for the images to be shown where they were previously hidden.
1 - 4 of 4 Posts
