1 - 1 of 1 Posts
I think Boomie's got it.. bracing would probably be best, but it changes the internal volume which is very important. Maybe by adding some stuffing, you can make the internal volume "appear" bigger (counter intuititve isn't it) enough that the two balance out somehow. No idea how that works though..
As an experiment, you could cut some boards and clamp them to the sides of the box to see if that helps improve the speaker as well.
JCD
1 - 1 of 1 Posts
