21 - 30 of 30 Posts
Discussion Starter #21
ideally 2ft cubed is what i can be comfortable with, but i'll handle it if it's bigger. I have a 120w woofer amplifier handy for amplification.
Multi-use is always a good thing, but i'll sacrifice that as long as it does a good job in the studio. Just for the record, my studio is about 30 feet by 10 feet.
Ok. Since you have a large room and your power amp is conservative at 120w that makes me think that the LoRider 18 really is a good choice for you. It's efficient so it'll still get loud off of that 120w and it should have great SQ due to a light moving mass and very low inductance. I understand that it's right at the limit of what you wanted to spend on a driver but it's a solid piece that should last you for years.
A 2' cube is about 6cu ft of usable volume for the driver. I think with just increasing that a little bit you'll be in fine shape. I'll model something up later.
GPM, thanks for the help, much appreciated. I'll plug those parameters into Winisp and see what it gives me. also, i don't care how big the enclosure it has to be, i'll make space for it.
Greets!
You're welcome!
Hmm, my experience with this driver is that except either in a small room or possibly EQ'd ~flat in a corner, a typical BR or sealed alignment isn't going to do the 20s well as Ricci noted. TL is pretty much it IMO. Also, now that we know the room is 30 ft long, its 1st axial mode will be around 19 Hz, so no room gain of note to help the TL's sagging response in the 20s, making the LoRider in a 4th order band-pass (BP) a much more viable choice and it will be a bit smaller at only ~11 ft^3.
GM
With the Low Rider 18 a vented box of 10.0cu ft net volume tuned to 25hz with an 8" port 15.7" long looks pretty good. That'd be a box of about 24"x24"x39" external to end up with that volume after driver port and bracing displacement. It is about -6db down at 27hz and should do about 110db or more from 24hz on up in your room with 120w. You'd want to use a 20hz rumble filter with it. Later on down the road you can up the power to about 350 or 400w to add about 4db more headroom.
Discussion Starter #25
hmm it looks like I'll have to do layering of the bass response in the studio for this album. I have no way of building this kind of system for now.
Rici, this configuration, will it be usable in small live venues, or is your suggestion purely for my room's configuration? I'm asking because, if I put this project off for next album's release, i want to know how dynamic this setup will be in different indoor settings.
Discussion Starter #26
oh also, what can you guys tell me about dampening material and would this help my project at all? If so, how?
Apparently, Ricci has moved on......... You'd have to define 'small' since with Ricci's alignment's ~800 W limit (if kept within Xmax) it would be plenty enough back when I helped folks with their portable sound systems, but on a live audio thread recently I got told in no uncertain terms that if a speaker couldn't do >130 dB/m from 40 Hz-up it wasn't a contender, which this alignment won't do unless you use four with several kW on tap.
Cabs this big require at least one each of all parallel surfaces covered to damp down its eigenmodes (standing waves), so typically one side, top and back of a vented cab gets covered with 1" acoustic fiberglass insulation or similar 'faceless' insulation.
WRT the 'Thunder', being a PR vented sub it's tuned too high IMO. These are best suited for <20 Hz tunings where the vent would be unacceptably long for a low vent mach. Best also to use two drivers/PRs in a bipolar layout to ~cancel out their vibrations as pioneered AFAIK by the Servo-Drive Contrabass special effects sub used in theme park, etc., sound systems.
GM
It kind of depends like GM said, whether it would be enough for live sound. Used sensibly in smaller places and possibly adding another cab to make it a pair down the road, it could be decent enough. Many of the live sound guys poo-poo anything that won't do 135db peaks easily, but those guys are usually doing very large scale productions with professional rigs. It'd be plenty for live bass guitar and like I said a pair would be ok for bar band/weekend warrior SR work.
Discussion Starter #30
certainly, only this project is for a very small studio, not for live sound. My goal is really to be able to monitor music down to 24hz.
21 - 30 of 30 Posts
